I had set up my system just right, speaker position, component choice, tweaks etc. Really happy with it, no urge to upgrade at all. Then I moved house. Once I set up my equipment again, it had lost its magic. Hmmm just speaker positioning/different room shape I thought, but after a while I realised that wasn't it. I wasn't enjoying listening to the music at all. Something was off.
In setting it all up, I had done everything as before, except a couple of chassis grounding wires on the two Innuos products. I finally got round to putting them back, suddenly, WOW! its back. Two little silver wires from one of the case screws on the side to the earth point on my PSM156 made all the difference. I've spent the whole afternoon listening to music again.
Bass was boomy and flabby before. Now its tightened up again and in proportion. Focus of the music is better. Details arent sharp and cutting, just detailed.
If you have both a Zenith and Phoenix USB reclocker, try it. Just undo one of the small screws on the side and screw a wire to the side of the case. Then back to an earth point. Not attractive but effective
