My grounding cable on my tone arm is going to be too short to reach my amp in its new location. Is there any type of cable to use or can I just get some cheap electrical stuff and a chocolate box to connect the 2?
Based on my experience some bell wire and a chock block will be fine. If you want to be neat you could solder the joint and then put some heat shrink round it.
