Ive done a few pairs. 1st 2 pairs i did were a breeze once I got the dustcap off (this was the tricky bit- glueing a new one back on is the easiest bit). Once shims inserted you have the cone firmly in place to work on/ and reassurance it will sit perfectly central -so I would take dust cap off as a rule- degunking is easy, use a knife and scrape etc/ say a blunt stanley blade best. Glueing is easy/ nothing to it bar common sense, as is joining together. Then lastly glueing a new dustcap on, as said easiest bit.
I did get a bit cocky and tried a refoam leaving dustcap on.. I had a mare tbh, the joining wasnt as easy, and wasnt sat perfectly central, so I wasted a new foam ring (pain as I had two sent from US, so at the mo Ive one 4" mid done, one orig with holes).
To remove dustcap I used again a stanley, using the point with real care and concentration, obviously avoiding any nip into the main cone underneath, or the adjacent voicecoil protruding, gently working round prizing it off. I actually reglued the orig one back on one pair/ absolutely just like it was before once done).
