pil
Just picked up a lovely 125 but on the few seconds it makes a very slight noise then totally disappears and keeps speed an plays fine
I cleaned the belt which I think was probably the original. Just bought a new one
Also cleaned the sub platter where bets sits any the small white pulley
It hasn’t been used since the late 80s so is doing sterling work
I cleaned all the bearing out and put fresh oil in
would just like to get it to work as there are many things on the 124 and 125 that make them easier to use as you get older
Any ideas?
Any ideas?
