Tellurium Q Atoms & Listen Pre - Bi-amping Help please
D-C
Hi all,
I just purchased a Tellurium Q Listen pre and would like to bi-amp. I've done this with another preamp no problem, but I'm not entirely sure how this works with these.
You should be able to see from the attached photo I've set up the combo as follows:
Atom 1 (bottom of stack in photo):
Right speaker output.
Bi-amp out: To Atom 2 Input (middle of stack in photo)
Atom 2:
Left speaker output.
Input: From Atom 1 bi-amping output.
Bi-amp out: To Pre Out on Listen Preamp
Listen Preamp:
Input: From Atom 2 Bi amp out
a>
Is this correct?
Thanks all in advance,
D-C
Thanks CJ14, I'll try again:
I think the photos were too big.
1)
Atom 2 (middle of stack in photo):
Input: From Atom 1 bi-amp output.
Listen Preamp (Top of stack):
I get the feeling this is wrong and should be:
2)
Pre out: To Atom 2 Input
Input: From Listen Preamp
Bi-amp out: Atom 1 (bottom of stack in photo):
Input: From Atom 2 Bi amp out (middle of stack in photo)
Cheers,
D-C
All sorted, as suspected, 2nd wiring was correct.
The sound out of the listen with the two Atoms is meaty (highly technical terminology).
