+1. I went from a 555 on an NDS to Teddy’s. I prefer them. To be fair, some don’t, describing the Teddy’s as overly analytical. I like as much detail as possible. You pays your money……I've got the TP XPS on my NDS and it works fine. (No cash to compare to the Naim product)
I then added an XPS Plus once funds allowed and it was a very nice uplift.
I have a Pardo T-XPS on my Naim nDAC. Substantial
improvement, and I preferred it to a Naim XPS-DR.
As above. The TP website has (or used to have) a very good description of the difference in design philosophy between the TP and Naim. Do a bit of searching, it’s probably still there.I have a TP XSP, and it does what Jono says. I've never directly compared it with Naim's, however. One thing I don't understand is how TP can make them so light. The Naim XPS is, yes, four times the size, which in my mind is a drawback. But the Naim must also be five or six times as heavy. I know the TP website says, "superior design," etc., but how can the power supply inside the TP casing be so light? The late PR1 (TP preamp that was discontinued) was the same, by the way.
Here it is;As above. The TP website has (or used to have) a very good description of the difference in design philosophy between the TP and Naim. Do a bit of searching, it’s probably still there.
I had a 555 on my NDS and a 2*SCDR on my 252 & Superline. I now have TP.I use a Teddy pardo on my Naim unitiserv ( Naim don't have one for that).
However I opted for the XPS-DR on my 272 and the sonic improvement was obvious.
I dont know how the Teddy pardo compares however I would be nervous about warranty on new Naim gear if a third party causes an issue.
Also clearly Naim have designed PSU's for their range so i guess depends on what has been spent on the Naim kit.
Teddy pardo on XS range maybe great - but not so sure on say NDX2 282 252 or 500 series.
