glenn jarrett
I have been asked to have a look at a friends amp
the amp powers on and the vu meters light up but no speaker relay click
the operation light is not lit
you can hear the big power relay click on and off
the main power supply is working both caps test ok
i have had the board out and checked all the caps replaced two which where out of spec
replaced caps C502 / C504 100uf 6.3v and R502 which was burnt
put it back together and still the same but when switched on R502 gets very hot
i have included the manual
https://www.manualslib.com/manual/387765/Technics-Se-A900s.html?page=1#manual
20200716_152600 by glenn jarrett, on Flickr
20200718_153233 by glenn jarrett, on Flickr
