eddie pugh
I'm after a bit of help from the gurus out there
I have the plate amp from a fairly old Tannoy R 15 subwoofer here and it's blowing fuses like no tomorrow.
Tannoy were very helpful and managed to dig up a circuit diagram.
https://dl.dropbox.com/u/71645468/Tannoy St200.pdf
This thing is allegedly good for about 300 watts It has 2 No TDA7294 Chip amps feeding a dual voice coil 15" driver
All I know so far is that if I put 2 new slow blow 6.3 amp fuses in the transformer output lines it releases a little whif of magic smaoke and blows its main input mains fuse T2 amp. It happens a little too fast for me to see which component emits the smoke
Before I got the circuit diagram I initially thought that each fused transformer output line powered a separate TDA7294 so I tried pulling one of the fuses to see if I coulsd home in on the fault. I was a bit surprised to find that if I only put one of the T 6.3 amp fuses in they blow with a nice blue flash leaving the mains input fuse intact
Does that give you something to go on.
I now see that each fused transformer secondary feeds a conventional bridge rectifier. The tranformer is a centre tapped +/- 32volt job if that's any use
I must say I was a bit surprised that such a massive sub had such modest amplification Made in China to boot
I sourced some replacement TDA7924's and swapped one that looked a bit dodgy. made no difference at all
Any help greatly appreciated.
eddie
eddie
