I want to buy a new system. The present arrangement of Heed DT/DA, Quad 34/306 and JBL LSR6332 works just fine, but I still hanker after something a bit better yet.
I have an analogue source that I want to continue to use. What I also need are two digital sources (CD transport and a streamer for Qobuz or whatever; no local data storage), a way to change volume and switch sources, amplification of some sort and speakers.
The conundrum - there's a totally bewildering array of possible permutations for providing all this.
Option 1 - let's call it the Tony L solution: Get a separate box for each function. Buy stuff that holds its value (i.e. used), can be repaired indefinitely and offers a bit of fun.
Option 2 - let's call it the Keith solution: Have as many functions as possible in the speakers (Grimm, Kii, AVI, to name some names that readers of this forum may be familiar with), leaving only the sources as separate boxes. Probably means having to throw away the speakers at some point as they will probably follow the computer business model and get outdated/be no longer supported.
Option 3 - any number of solutions between the extremes, i.e preamps or integrated amps with integrated dacs or streamers, allowing for both active and passive speakers.
Which option do you prefer and why?
