Yank
Bulbous Also Tapered
Stylast is the way, as I am sure others have already posted upthread.
Stylast is not a cleaner.
I thought it was going to pull the cantilever off. Used once and never again.
Vacuuming using a bar with Velvet pad on such as project or okki just increases chance of moving any dirt from the record into Velvet and on to another record.
You'll know that you are OCD when you find yourself cleaning the toothbrush that you use to clean the velvet pad that is on the RCM that you use to clean your records with, such that you don't have to clean your styli so often; the tip of which does a pretty good job of cleaning your record grooves if they aren't too far gone!
Really, ? I don't know what it is (the blurb doesn't say) but it makes a lot of claims, none of which is being a cleaner as such. It's not a lubricant either. I do wonder what this stuff really is. It achieves less friction between groove and tip but it's not a lubricant ! It's liquid, so what on Earth is it? I think it's a cleaner cum lubricant.
Stylast works by creating a local gas layer reducing physical contact between the stylys and groove wall. It also keeps the suspension elastomer pliant.Really, ? I don't know what it is (the blurb doesn't say) but it makes a lot of claims, none of which is being a cleaner as such. It's not a lubricant either. I do wonder what this stuff really is. It achieves less friction between groove and tip but it's not a lubricant ! It's liquid, so what on Earth is it? I think it's a cleaner cum lubricant.
