Honestly I have never noticed any difference between the analogue and digital inputs, to begin with at least set the 8Cs to analogue and use your current set-up.
I use an RME ADI ‘Pro’ which can send a digital signal to the 8Cs , it just means changing the input on the 8Cs and changing the speaker connections.
Keith
I am considering trying the 8c speakers. I currently have a naim NDS and unitiserve to stream, but I guess as the 8c has a dac I might be better off with a dac less streamer such as a dCs network bridge. Anyone with experience/suggestions?
I just think you should use what you have available.Doesn't look like that is a streamer. But thanks anyway.
