MVV
Hello Fish, I'm looking for a pair of stand mount speakers to match well with an Audio Note P2 se power amp. (single ended valve class A)
Specifications are:
Maximum Output: 18 Watts RMS per channel into 4 or 8 Ω loads
Tube Compliment: 4 x 6L6 / 5881; 2 x 6SL7
Input Impedance: 100 k Ω
Power Consumption: 165 VA
Fuse Ratings: 2 A anti-surge (110 to 120 V supply); 1,2 A anti-surge (220 - 240 V supply)
Currently I'm using Epos ES14s the presentation of which I really like but they are getting on a bit and in theory not a good SET match although plenty loud enough for me.
It will be a used purchase and budget will be sub £1500.
Specifications are:
