Geoffreybombom
I’ve removed 20 small caps from my amp, new Nichicon caps have arrived, any tips on soldering them in would be very welcome. Thanks.
I disagree, a more powerful eg 60W temperature controlled iron will solder to ground and power planes much better and cannot do harm.Don't use a high wattage iron. Unless it is temp controlled 18-25watts.
I was going to add this to @Retro post, all good advice, especially when working on old (50 to 60 yo) solder joints.The obvious question being: what did you use to unsolder the old caps?
I use acetone to clean the board before soldering the new components. I like a clean PCB.
Remove the excess of solder with a braid.
I don't use flux for most new components, the flux cored solder is sufficient. I will sometimes use flux for IC's or old stock components with slightly oxidized leads etc.Blutac is a good tip, do you use flux, thanks.
