YNWOAN
100% Analogue
As the Shun Mook thread has been so poular, why not have a look at Akiko Audio:
http://www.akikoaudio.com/en/akiko-audio/akiko-audio-audio-accessories/49-sanderss
These guys state clearly that:
Further, from their website:
It's won a Six Loons award...(bet you can guess who 'reviewed' it)
It has been scientifically proven that certain gemstones are capable of absorbing energy from their surroundings
Akiko Audio Gem 1 Gold
It has been scientifically proven that certain gemstones are capable of absorbing energy from their surroundings. Tourmaline for example has a piezoelectric effect. When an electrical potential is carried out on the gem the crystals will vibrate, causing the electrical energy to be absorbed. Every audio set up contains a set of speakers. All the electro smog present – coming from mobile phones, microwaves, Wi-Fi, energy saving lamps and other electrical appliances – can reach the speakers uninterrupted via the unprotected speaker cables. The interferences mix with the audio signal which results in a suboptimal and impure rendering.
Whilst developing the Akiko Audio GEM1 reaching the most optimal result was our number one priority. Which is why we exclusively use a mixture of natural minerals with various physical properties.
Because of the special build the speaker cable is filtered from above as well as from below. On top of that the GEM1 Gold comes with 22 carats gold, which causes more warmth in the midrange.
It is best to place the GEM1 as close as possible to the speakers. Because of its powerful working, one Akiko Audio GEM1 should suffice per speaker cable. A third filter, on the speaker cables behind your amplifier, will cause even more improvement
