kwmason
Won Ton On
CAn anyone confirm that when setting up my Dynavector P75 phonostage in enhanced mode with Dynavector 20XL cartridge that the cartridge is classed as a low resistance coil?
The specification for the cartridge says its impedance is 5ohms
The P75 instructions say set output level depending on the coil resistance.
I trust coil resistance and impedance are the same thing?
Im sure im right just thought best check
