Jim Audiomisc
I have never actually listened to R3.
Ironically the thing that probably most rekindled my desire to revisit digital this time was my newfound interest in classical music, particularly Shostakovich and while I can tolerate vinyl's surface noise with most music - dance tends not to have all that many quiet passages - I can't do it with classical. It destroys it.
(snip)
So where I am is that I'm waiting for MQA or hi-res to become successful for digital audio to become "accessible" to me. My next foray into digital will most likely be a much higher-end (than the Meridian USB thing) DAC with MQA.
Right, I have some bedtime reading to do on sampling theory.
Its a shame you haven't spent time listening to R3 FM as that would have been interesting. The reason being that R3 FM has often been cited as superb 'analogue' by those who complain about the awful 'digital' failings of Audio CD. Yet it has been distributed since the 1980s via a digital (NICAM) system that has fewer bits per sample and a lower sample rate than Audio CD.
The point here is that people can easily blame the bottle for what it contains.
Radio 1 will probably be processed to death. And also I suspect often starts with source material that has been processed to death. So you've listening to crapped-up audio content, not what the delivery engineering *can* do if used with care.
Here's a suggestion. Keep your eye on Radio Times or the iplayer. Install get-iplayer. Then when you see a live concert (e.g one of the approaching Proms) download it as a 320k aac file. Play that carefully.
It is 48k based on a 48k/24 input feed. (That is the BBC standard for internal distribution) It is a mere 320kbps aac. Yet it can sound superb. Often better than many Classical CDs. You or I might wish for a 96k/24 flac version. But FWIW when I've compared source LPCM files given to me by the iplayer people for tests I've found it hard to tell them apart from the 320k received versions.
If you like Shostakovich, though, I'd suggest you find a CD of the Philips label version of the cello cons by Schiff , Maxim Shostakovich and the Bayern Radio Orch. Or any of the Denon JVC series of the symphones Rosdestvensky and USSR CSSO. See what you think.
The Rosdestvensky versions seem to have been recorded by the JVC/Denon engineers setting the levels to not peak clip, and then sitting with their arms folded though a performance. Risky, but a quite remarkable result.
BTW If you like Britten, the remasting of the War Requiem sounds a lot better to me that either the original SET LPs or the first CD issue. (Which sounded worse than the LPs.) The 96/24 may be best, but I'm not sure. Quite amazing for a 1960s recording of a vast work that covers such a wide range.
