davidjt
My old caspian appears to function normally but emits loud spitting sounds on one channel when switching off - so loud in fact that this morning I disconnected the speaker first and have decided not to risk it any more.
Before I get out the tool box, does anyone happen to know whether this is likely to be ageing caps in the psu, or some other component in the soft-start? The former might be an easy replacement job - less sure about the latter.
(The last time I had a (Cyrus) pre-amp fixed via my local dealer, the cost was roughly equal to it's s/h value - making it a 50/50 repair/landfill problem.)
