Marchbanks
Hat and Beard member
‘Do you want an A77?’ my audio engineer friend asked, knowing that my hifi gear averages around 40 years old. ‘I’ve got two, and neither have been used for twenty years. They are just sitting around in my workshop - it would be better if you could put one to use. Take a look at it and pay me whatever you think it’s worth in Belgian beer.’
The next thing I knew he had powered it up (!!) and sent me a photo.
‘The right hand spool needs some TLC’ he said enigmatically. ‘It worked when it was last switched on, though.’
I picked it up and took it home. I started to clean the marks off the front panel, then decided to look inside. Screws on the top securing the case very rusty. A bit of rust inside too.
I thought I’d do the front panel properly, so I downloaded the service manual to see how to disassemble it. First step, take off all the knobs. Can’t get the power knob off, the shaft is rusty, the knob is plastic and I don’t want to snap it. That will do for now.
Tonight I’ll sit down with the manual and a glass of wine and decide whether to buy all parts for a recap from Mouser or buy a kit from eBay.
Good things:
It seems to be a factory MkIV HS model with the speeds printed on the fascia rather than added afterwards.
Virtually all of the printing is intact.
It powers up.
At least two of the motors work, apparently.
I haven’t paid anything for it (yet.)
Bad things:
Corroded chrome on knobs and switches
Switches and pots all in need of serious lubrication (at least)
Rust
Counter won’t reset
Wooden cabinet rather tatty, and veneer is falling off
My estimated value so far - three bottles.
Thanks to @337alant for his offer of help, suggested plan of action and links to resources.
Good things:
It powers up.
Bad things:
Rust
Counter won’t reset
