S-Man
StrivingON
I've just tried a spare 550VA 240V traffo from an NCC200 build in my Bedini 25/25. This one is a torroid and the original 115V is a 210VA EI.
When I flick the switch the transformer hums quietly as expected and then the ground lift resistor, that I installed from the centre of the PSU caps to the safety earth, glows orange and melts its insulation.
I quickly switched off the amp and haven't attempted a restart. The resistor is a 1W 10R and was added by me (with a 0.22uF cap in parallel) to get rid of an earth loop, I don't need it at the moment, so I could just remove it.
Why is it doing this? Is it normal to have a current flow to ground on startup (from the transformer centre tap)? Should it be a 5W resistor?
All helpful advice greatly appreciated
Dan
Did you have any other pieces of equipment connected during this switch-on?
If something else is connected to earth and for some reason is pushing current through the 10R resistor in the power amp you could get this situation.
I suggest refitting the 10R and winding the supply voltage up using a variac. Monitor the voltage across the 10R as you wind the supply voltage up. Keep the 10R voltage below about 3V.
You need to find out where the earth current is coming from!
