...I suspect he meant that 'all internal wires show continuity and none have been cut or broken off short'.No tonearm rewiring required.
IIRC, Vic knows his way round both a multimeter and a soldering iron. When he said...
Customer should be well impressed with the girth of the current 'LOW CAPACITANCE - HIGH PERFORMANCE - TONEARM CABLE' from Rega, then.Yes, all internal wires (and tonearm cable) are OK. Customer just wants to swap the tonearm cable. Done a rewire myself and it requires tons of patience to get the wiring loom thru the small holes in the arm collar and arm tube, plus the risk of damaging the internal ground cable.
