Sue Pertwee-Tyr
Accuphase all the way down
I have a Makita battery drill which came with one 3Ah battery, model B1830. It's been great, but now and again I could use a second battery so recharging doesn't interrupt play. I don't use it a lot, but when I do, that can be limiting. I'd probably go for a slightly larger capacity, maybe 4 or 5Ah, so the B1840 or B1850 unit.
Amazon has a variety of replacement offers, the Makita ones are around 2-3x the price of the Chinese no-mark brands. Given it's not for heavy or semi-pro use I'd be fairly happy to get one or even two of the cheapies, but the feedback seems to suggest reliability is a bit of a lottery.
Do the assembled pfm luminaries have any Chinese brands they can recommend as being a reasonable bet in this regard?
