I always prefer a deck with a lid - just old fashioned I guess
P6/P8 Bettered by a £700 project X1..
Bettered on paper? Big deal. I've seen, used and repaired quite a few ProJect turntables and I wouldn't buy one for my own use. I'm reluctant to sell them to other people these days as I feel bad about it. I strongly dislike the way ProJect build their turntables. They might dress things up to look trick but underneath the built quality can be shocking. They typically employ the cheapest methods possible. I'd take a Rega over a ProJect every time.
The caveat would be that the Rega P1 is build down to a price and is not as well made as the rest of the Rega range. Still better built than the equivalent ProJect and sounds fantastic.
You can upgrade your RP6 with a groovetracer reference subplatter and limm double or triple pulley and bronze bearing hub. Maybe upgrade the plinth and install leveling feet from limm as well.
I can’t imagine the rega RP8 sub platter system to be better than the groovetracer.
The Planar 6 is Rega's ultimate old style Planar and I don't think it will be revisited, skeletal is the future.
Practical also. I've seen the amount of dust open turntables can collect. I deliberately sought out an RP10 rather than a P8 because it had a lid.
Even with the lid, the RP8 and RP10 still have a dust problem, they're still open underneath.
Rega's dust cover protection solution looks perfect to me.
I’m so fed up with lids going dull and getting scratched that I just leave them off and instead, dust the deck periodically. I’d have no issue with the current skeletal Rega models at all... in fact the lift off dust cover would probably live in the box too.If your going to commit hundreds or thousands of £££ for a record player you should be prepared to look after it and keep it clean, it only takes a minute or two with a make up brush and a micro fibre cloth. I've owned a few lidless turntables and never had an issue with dust, a square silk scarf draped gently over the TT keeps the vast majority dust free in between times. In practice I found the most difficult bit to actually keep clean is the lids that are found on Regas & Linn's, etc.
