The picture in the OP external forum thread seems doctored or photoshopped.
You wouldn't necessarily have to. If you take the picture at the right angle etc you could easily exaggerate any bend. However, some people have had turntables replaced which, if correct, confirms that there is or was an actual issue.
Overall, the "sag" seems like 99.9% non-issue.
Yes, I think that is the important takeaway.
It doesn't matter what you buy, a car, a TV or a record player. Or how expensive or well made it is. There is
always a possibility that something will go wrong with it. If it does, it
is the manufacturers fault, they built the thing, so realistically there are only two things you can expect from them.
That they build their products to be as reliable as possible and if they do go wrong they'll be there to sort it out. You have to concede that Rega pass this test with high marks.
Yes, it is a bit crap that people have had bent plinths but context is everything. The thousands more with flat plinths don't post on the internet about it. Happy customers far outweigh the disgruntled ones. Your chances of buying a Rega turntable and having no problems whatsoever are probably in the 99.9% ballpark.
I think it's perfectly fair to flag up and talk about issues like this. However rare, if you get a bad product you don't care that everyone else's ones are fine and I think it's good that manufactures are aware of the implications of quality control breaches. But the bottom line is that a wonky product is always a possibility and it's more likely if you buy a product
not built by Rega!
