davidsrsb
I have been experimenting with my RP3 (240V motor) to measure speed, wow and flutter.
I have two test records, the HFS75 with a 3000 Hz tone and the Epsilon Ultimate with a 3150 Hz tone.
By recording the tone using Audacity, a bit of cleanup and then processing in a PLL circuit in LTSpice simulation., I can see what is going on.
The HFS75 speed is almost spot on at 2999 Hz, the Epsilon is 3200 Hz, about 1.5% fast.
Probably the truth is somewhere between, most beltdrives run a little fast.
Both tones show about +/- 10 Hz FM at 0.55 Hz, which is eccentricity at 33 rpm
What is odd is that both tests show this FM also AM modulated at about 20 second period. I wonder if this is my mains as I cannot think of any mechanical resonance this slow.
