Actually only early Cursa3 / Maia3 / Exon3 / P9 power supply have plastic facias.
Later versions all had the alloy ones .
Saturn , Elicit , Ios have only had the alloy facia.
So if buying s/h best to check . There are a couple of easy to spot differences.
AFAIK.
Michael.
I bought a P9 in 2011 and the faceplate is definitely an alloy of some sort. As Klyde points out the entire casing is solid and impressive. .
I actually think it looks and feels nicer than the casework and facias on my naim boxes. I was actually toying with the idea of getting an Ios phono stage so was disappointed to see it has now been 'upgraded' to the Reference casework, as has the price...
I dont know if Rega will be phasing out their entire classic range (Saturn, Ios, Elicit), but it would be a same if they did. Aren't they aware that it takes time for their customer to save for an upgrade or addition?
Example: a customer just bought a Saturn, and would like to add a matching Elicit in a year or two, but cannot because Rega decided to replaced the range by different models and look.
Frustrating,
Brian
Naim seems to do just fine ... even expanding their product line with the same look.
Buy a CDX2 ... want to add a power supply ... not a problem because you have different options available: XP5 XS, XPS or 555, and they look the same.
Regards,
Brian
It's too big that P9 PSU box.
It only supplies clean AC to a small motor.
Stick it inside a Brio R box.
IIRC it was a modified Rega power amplifier with an clean oscillator on the front and adapted to drive the motor load, so perhaps it was more cost effective to adapt an existing product.
Nevertheless it would be nice to see something new and smaller for the next range topper TT.
