Boris the madcap
Hello all
Anyone knows the weight of the rega p25?
Thank you!
Thank you!
If that’s per foot, you’ll be well within that, I’d have guessed at about 5-6kg. They’re not heavy turntables.I need to know because, to isolate the p25
(the wall bracket is not possible) there are
a feet from isoacoustic, called orea bronze
with good reviews, but this feet only support
3,6kg per unit.
