-alan-
After a bit of effort (and a steer or two from here) on rigging up a kitchen-based tuner/amp/top of the cupboards mounted speaker and aerial system, (and refurbing my old Mission 700s with new rubber seals along the way) I though I'd nearly got it cracked. But there's still something not quite right.
For long period of time the set-up works perfectly, good reception and sound, but every so-often the sound volume drops to the point where I have to shift the volume control from 3ish to over 7 on a ten point scale to restore the sound - and then almost get deafened when the problem disappears anywhere from 30secs to 10 minutes later and max volume comes blasting in again.
Current set-up is the aforementioned Mission 700s driven by a Nytech 202 amp and a Linn Kudos tuner. The aerial is a little twin telescopic arm device pinched from a neighbouring tv. I know the aerial isn't wonderful - but the sound when everything is working well is perfectly acceptable.
I've swopped amps in and out to no avail, and soldered up a break where the co-ax cable meets the base of the telescopic arms - but the problem remains. I thought it might be due to the equipment and aerial sitting close to some of the main power cables running round the house - and can sometimes recreate the problem by switching on some of the heavier duty electrical equipment in the area like the cooker or the dishwasher - but not on a repeatable basis.
I'm flummoxed because I can't tell if it's a reception or an equipment problem. I was wondering if somebody could shed any light on the topic before I have to concede to the missus' request and remove the whole set up from 'her' kitchen ?
Any thoughts much appreciated.
