villan
Member
Just picked up a pristine 306 that had been mounted since new at the back of a hifi cabinet so has hardly seen the light of day, let alone been bashed around.
I'm going to replace power caps and the C7 47uf caps (are these electrolytic? I'm assuming so) and leave the rest alone. I'm thinking of copying another member (John_73, hello) to keep things simple and go for Kemet ELGs and Vishay 136 because it's doing my head in trying to make a decision for myself and the Kemets seem readily available and are not too tall. Any other suggestions welcomed however, but the Kendeils everyone seems to favour don't seem to be available.
I want to change the input sensitivity to 1.0V. Dada does this by using a R27 resistor at R13. Quad spec for existing resistor is 9R 0.25W metal film. So my question is if I go for R27 does the wattage stay the same or will this change?
This is a near-field desktop system. I'm planning to output directly from a PC with a Xonar Essence STX card and was thinking about getting one of those little Nobsound passive pre-amps just for a volume control.
