nojobtoosimple
Active Member
Yes, signal 0V and mains earth are separated here. The bond that you can see from the DIN connector to the case is grounding the DIN connector shell and cable shield and is not connected to signal 0V.I believe that 0V and mains earth should be separated if you adhere to the Naim philosophy of only connecting to mains earth at the source.
Cheers,
Jon
