Hi,
Hope someone can help me with a problem. I have tested a 401 but only get sound from the left hand channel. Swopping phono leads over confirms that the right hand channel is missing.
Will this be the cartridge?
Also how do you get the platter off to check serial number.I didn't want to force it. It is a flush mounted strobe type in a floating plinth with 4 screws/springs in the corner.
Garrard SME 401
thanks
JP
Garrard SME 401
thanks
JP
