Hi all - I turned on my Croft micro 25 pre amp this morning. It turned on as usual but no sound came out then it turned itself off and won’t switch back on.
I’ve checked the plug fuse but are there some internal fuses in the unit itself that could go? If so are they easy to locate and change if I open it up?
Any other possibilities worth trying before I contact Croft
thanks Jon
thanks Jon
