Yes, although I'm not the biggest fan of them. There are various types of which my favourites are probably based around autoformers. Tribute and Intact Audio make these although whether there are non-DIY versions, I don't know.
Alternatives include resistive attenuators either using a conventional potentiometer (ALPS, Noble etc) a stepped attenuator or even one based on LDR's (light dependent resistors, search for Eva II from DIYParadise.
Also popular are transformer volume controls (TVC's) but I've yet to hear one I really like. Some people swear by them though so try to hear one if possible. Promitheus, GlassHouse (from HiFi Collective) and Music First Audio (amongst others) do these.
One other possibility gaining in popularity is the BL Audio LP1 which is a battery operated active pre (of sorts) although I've yet to figure out quite how it works.
http://www.cattylink.com/page199.html
Ive done a little homework here, and am currently using the tribute autoformer. Tribute are about to bring out their autoformer in a boxed up already to go pre-amp. Intact do one in a case on request, and also Bent Audio do a remote control version of the Intact Audio autoformer too. So now, 3 options for one of these.
DIY is still the cheapest way to get them going, but not everybody has the skill.
Hifi Collective have only one left of thier top transformer passive, which uses massive C-cores. This is good too.
I am finding my tribute lacks the punch and dynamism of an active pre-amp, but also foregoes the unwanted ''colour'' to the sound so many pre-amps add, whether it is wanted or not.
For the amount an autoformer (AVC) passive costs to build DIY, I could not imagine getting a better active pre-amp, which simply costs a lot of money in parts.
I have visions of ending up with two pre-amps, but at the moment this is my favourite option (the tribute).
I have tried the lightspeed passive. This one was a little strange for me. It pins you to your seat as if you've been hit by lightening. I found it rather unpleasant!. Almost full volume with just a couple of notches on the control didn't appeal either. It is 'straight wire with gain' though.. but whether you like the experience is another matter.
A resistor based passive can sound great too. I dont like them as much as the autoformer. I like them better than the lightspeed thing though, to my tastes. Of course, there is much variety in the quality of resistors. 'top' resistors, and you're in AVC territory, so it's really a matter of which presentation suits you.
SpeedySteve picked up a used 'prometheus' passive for under £150. This is dirt cheap for a transformer passive, and would be hard to beat for this kind of money. Good luck finding one so cheap though
Caio
