I'm putting together a system from scratch. Speakers are likely to be shahinian compasses (can't afford obs), and a chord hugo as the front end (I'm a Qobuz convert!). I will use the pre amp section of the hugo as I don't use other sources. I'm not sure what power amp to use, I will probably do it in 2 stages, getting a reasonable power amp now and then upgrading when funds allow.
I'm a tech novice - could I use the hugo directly into a naim nap140? I can't afford a chord amp or a dynavector for the moment. I do
Like the nap 140 (remember one from 20 yrs back!).
Advice will be really appreciated!
