norriemal
Hertz and Minds
I picked up some homemade crossover boards that I thought were decent. Van den Hul wiring with just a large air core inductor on the LF. I have no way of measuring it. The HF has a Philips 6.8K 100 MKC capacitor in series, a JTM 4R7 5% wire wound resistor in series and a 10W 10 ohm wire wound ceramic resistor in parrallel.
For someone with experience in crossover manipulation what is the ballpark crossover frequency in such a simple crossover with a 6ohm or 8 ohm tweeter. I have the crossover in a little sealed box with a Monacor SPH-174 KE which sounds good enough to try mated with a better tweeter than the cheap one I threw in to test it out.
I have a nice SEAS that will cross low but I'd like to try an Emit K that would have to be crossed a bit higher.
Any advice on ball park crossover as is. If I know roughly how high the inductor is letting the mid bass work I can mess around with a dedicated HF for the tweeter at a later stage.
