I’d welcome some advice, please, as a new Picoreplay user. I’ve seen similar posts and have tried to learn from them. However, I’m still stuck:
I’ve recently changed from a Synology DS218j (which supported LMS) to a Synology DS218 and which no longer supports LMS, so I bit the bullet and set up an RPi running Picoreplayer and LMS, pointing to my music share on the NAS. All’s fine except that I can’t see my music folders, which are in /volume1/music.
NFS is set up and I’ve edited the share’s NFS permissions, including (temporarily) setting a wildcard hostname, setting Read/Write privilege, Squash: map all users to Admin and allowing access to mounted subfolders … and confirmed that the mount path is /volume1/music
On piCorePlayer [LMS] (Setup network disc mount) I have the following:
Mount Point: /mnt/Diskstation
Share Name: /volume1/music
Share type: NFS
Options: vers=3, uid=1001,gid=5
I’m not too sure about the Options field, though I’ve been working my way through the NFS version numbers.
The share seems to mount correctly and I can see it when I browse for the LMS media folder, but I can’t expand the selected folder which I’d expect to be able to.
It’s all pointing towards me not being able to access the share subfolders, but I can’t see why. I’d be really grateful if anyone could point me in the right direction.
Many thanks in advance.
Pieter
Share type: NFS
Pieter
