I’ve just bought this ‘hi-cap’ kit from a fellow member and today I finally had the chance to look at everything properly. The case is in near mint condition, a good start. The kit includes brand new Kendeil’s and a reconditioned regulator board, everything else is original. I’d like to start rebuilding this asap but have a few questions before I get the iron out.
1. Firstly do I need to use thermal paste on any of the components? The screws for the bridge rectifiers have some white residue which suggests to me there may have been some there before?
2. Is there anything else worth changing before I put it all back together again? I’d like to keep it as original as possible but don’t mind tweaking it slightly if quick gains are to be made.
3. I could do with some help in wiring this thing up. I have a basic understanding of electronics but wouldn’t be able to make a calculated guess at what goes where! Below is a photo of the unit itself with components in situ ( I now realise one of the caps is the wrong way around btw). I’ve also knocked up a quick diagram/schematic where, using all the photos of hi-cap internals I could find on the web, I’ve hopefully shown things wired up correctly.
However there are still a few things I’m unsure of:
a)The green and grey wires from the LED array board are not connected at the moment, where should these go?
b) I couldn’t really work out the pin configuration on the bridge rectifiers but found another thread on here which mentioned the pin 90 degrees out of alignment with the other three was +ve? Is my wiring on the drawing correct?
c) I have this diagram from LesW
I’m probably being a complete tool, but I’m not completely sure of how his DIN pin configuration fits with mine, and as such I’m not sure how to complete the wiring to each DIN. I’ve also noticed that DIN 1 in my diagram should be wired differently to the other three? Is this correct?
Any help greatly appreciated.
Cheers
Cheers
