On my 2nd system, my 140 feeds my 62.
I just got a HICAP to power the NAHA2 on my main system, so that freed up an Olive Flatcap. So, I figured that I'd put the FC into the 62/140 system.
However, the FC doesn't power my 62 (no green LED or sound). The FC had powered the NAHA2 from the 5-pin socket, so the 5-pin SNAIC should do the same. I put a meter on the SNAIC and I read 24.8 vdc from the +ve and the -ve as well as the two +ve's.
So, does it matter which 4-pin socket I plug the 4-pin SNAIC on the FC (the one that goes to the 140) ?
Obviously I removed the link-plug to plug in the 5-pin SNAIC and removed the 4-pin SNAIC from the 62 and then plugged it into the FC.
Initially I had the 4-pin SNAIC plugged into Socket #1 and got no-sound. Plugged it into Socket #2 et voila ! Musique !!
I then tried to use socket 1 again and it worked briefly. Now none of the other sockets work.
So I think I have to clean the SNAIC pins, maybe 'tweek' the pins in the sockets.
I opened her up and everything looks pristine inside with no movement of the board holding the sockets.
Is there anything else I could try ?
