garyi
leave blank
Ideally I would get the 600 as I can afford that but according to the interweb I will not have 'commander mode'
Question is do I need 'commander mode?'
The reason I want a flash is simple, I have two lenses I use now and both are reasonably long, pictures taken with flash results in the lower section being darker where the lens got in the way. On macro its obvious, not that I use it for macro but at normal lengths it results in the lower portion of pictures being ill defined and grainy. its most odd.
