dsg
Formerly bearded
Can anyone help with this? The left channel of my Superline has started making a sound like gently blowing on a microphone. It started several months ago so I took it to a Naim dealer. They plugged it into their system and it worked perfectly during an extended test so I took it home again. It started making the noise again when I got it home but then suddenly stopped while I was fiddling with the tonearm earthing cable and dropped the cable on the top of the Superline. It caused no more problems for several months and I thought it had been some sort of weird static build-up or earthing problem. Now it's come back.
Moving the Superline around and switching off other electrical equipment in the room doesn't make any difference.
Plugging the tonearm earthing cable into the pre-amp or the Superline makes no difference.
It's definitely the Superline because it doesn't happen on any other input of my pre-amp and continues to make the same noise when I unplug the arm cable from the Superline (i.e. when there is no input).
The Superline is powered from the Aux socket of a NAC52.
Annoyingly I forgot to fill in the extended warranty form when I bought the Superline so I'm in for a full Naim service charge (£400 plus) if I send it to Salisbury to be checked over.
Any suggestions how to fix this problem would be gratefully received.
Damian
Damian
