MJS
Technical Tinkerer
As many of you know the later Naim CDI and CD2 players used the Philips CDM9 pro transport unlike the practically bullet-proof CD4 used in earlier the CDI and CDS or CDM9/44 in the CD3. These are rarer than rare now and only the lasers can be swapped out if you can find one, which cures 99% of the problems we've seen with them.
For the 1% with a faulty turntable motor there hasn't been much you can do. So I compared the Naim circuitry with the Philips players of the same vintage which used the CDM9 plain transport. As it turns out, Naim's motor TTM drive circuit is almost textbook and the extra circuitry on the servo board drives the hall motor on the CDM9 pro. It turns out all you need is a simple push-pull emitter follower pair on the TTM drive from the main CDI board then connect the output of that to the turntable motor of a plain CDM9 (red to ground, black to emitter output). You can now use plain CDM9 transports in place of the Pro.
