The model I use is a Goal Zero Yeti 1250. I would have preferred one of the models which uses a lithium-ion battery, since they are much more portable. The one I have is so heavy that it comes with wheels installed and a removable hand-truck type handle.
It is not specifically marketed for hi-fi applications. It can be used for many different purposes. For instance, it can be connected to a solar power system. It can be charged up and put away for use during an emergency, like a power outage. Goal Zero makes them in different sizes. They have some that are small enough that you can take them camping to power a laptop or recharge a cell phone.
Both the dedicated circuit and the battery power supply remove much of the noise that is on the household circuit. As an example, my wife was watching the TV not long ago and I was using my water flosser. She commented that while I had the water-flosser turned on the picture was very distorted. I only have a superficial understanding of all this but I was unprepared for the effect of the battery generator on the sound system. I didn't think I had a noise floor, but it reduced it significantly. A wonderful upgrade.
Context: reinforced concrete (40 year old flats)
Acoustic grade rock wool glued with high strength glue to the ceiling. The whole lot concealed with a stretched, micro-perforated PVC (or some such) ceiling. Prior to this we had the ceiling light fixture replaced with wall fixtures - the one-piece completely smooth ceiling is just so classy .
The aim was not to soundproof the room above. The work seriously reduced the ceiling echo making for much better stereo imaging. The room is acoustically much "deader" than any other in the flat with neither rug nor curtain.
My most significant event was getting divorced , You should try it
Or were they removed from you?I removed the kids
Got two of mine Uni but one came back.To university
Sounds like a nice detailed set up. Always wondered about the MAs. I suspect they are fast. I use QED cable also but my B&Ws are fine with it and never move into the lug punishing area. I also bought Sennheiser headphones. I sit smugly in the corner a smile at my cleverness.Both mine are back so invested in some B&W P3 headphones.
For me, I am biamping my Monitor Audio S8, using a Cyrus 3 and q power.
Standard QED cable but I've run another set of QED silver anniversary cable to make the sound brighter on certain productions. Silver cable only run to the mid-range and tweeter connections.
Only caveat, is if you leave them active, and put a leanly produced recording in, it hurts the old lug holes.
I like that.The music should always come first...My best upgrade after many years was selling it all and now using Bluetooth headphones and speakers. Expectations have diminished and now I just enjoy the music whilst not trying to justify the money spent was worth it.
