Copper foil capacitors are my favourite, BUT I would buy the cheap, white Mundorf with the red writing or Ansar to start with. I'd argue that the Mundorf are the most neutral. They seem to get more coloured, the more you spend... I'd buy a cheap 3.3uf, 3.9uf and 4.7uf, and try them all. If one of these sounds very good, they will sound a bit better with copper foil. Copper foil caps won't fix a bad sound, they just sound a bit more grown up - smoother, but without losing detail.I'm using a Seas A26 10" woofer and Morel CAT378 tweeters, the woofer characteristics mean that they can be fed the full audio signal and only the tweeter needs anything in the signal path, the design I'm using is this one
I've been looking at components and wonder if the Jantzen Amber copper foil Z-caps or the Aubyn true copper caps would be suitable or are they overkill for the drivers being used, simillarly I'm thinking of Pathaudio 10watt resistors?
I think all I need then is to buy these along with hook up wires, binding posts and will damping for the back of the speaker then I should be able to finish the build and test before organising the veneer
Thanks, great advice and I'll do just thatCopper foil capacitors are my favourite, BUT I would buy the cheap, white Mundorf with the red writing or Ansar to start with. I'd argue that the Mundorf are the most neutral. They seem to get more coloured, the more you spend... I'd buy a cheap 3.3uf, 3.9uf and 4.7uf, and try them all. If one of these sounds very good, they will sound a bit better with copper foil. Copper foil caps won't fix a bad sound, they just sound a bit more grown up - smoother, but without losing detail.
EDIT: I agree with S-man. By far the most sensible way to do this is to buy the cheapest components to start with. Even the cheapest Mundorf or Ansar could be OTT.
I looked around on various site for ages, place such as Wood Veneer Hub and df richards (there were a lot more I looked at) but quantities were a challenge, either too little or the pieces weren't large enough or too large a minimum order quantityLooking good, Chris.
Where did you get the veneer?
Thanks, hopefully the end result matches the picture in my head......Well done! Very professional!
If I were you I would provide easy access to the crossovers (maybe leaving them outside the box for the time being?) since it is possible you will want to tinker with them in the future.
If I understand you correctly, yes. But others with more knowledge than me might confirm.Thanks, hopefully the end result matches the picture in my head......
Yes, should be too hard to do that, as the woofer gets fully signal I could piggy back from there using jumpers as if they were providing a feed to the tweeter then route that to the croossover to the second set of binding posts in order to finalise the specs, that should work, shouldn't it?
I think the veneer looks great, details will be great if you can. I can't find anything like what you've pictured.I looked around on various site for ages, place such as Wood Veneer Hub and df richards (there were a lot more I looked at) but quantities were a challenge, either too little or the pieces weren't large enough or too large a minimum order quantity
In the end I found just what I wanted via a google search with a veneer company selling on ebay, if anyone likes what they came up with I'll be happy to dig out the details
