cliffpatte
Speed camera anarchist
OK, so I got the Rodinal, the stop bath and the fixer. First attempt to load a roll into the Paterson reel was a disaster (kept on getting stuck and bent) so I took that one out of the changing bag as a throw away roll for testing my loading skills in the daylight. Eventually it worked after retrimming the end of the film, then I loaded reel 2 in the bag again.
OK, so at 25:1 it is 6 minutes at 20 degrees for Acros (actually 26 degrees when it started). One minute of agitation followed by an inversion every 30 seconds (ish). Then I drained the developer and stuck in the Stop and flished with water - result still some grey on the outside of the film but looking like images on the other side - aha, so need to put the fixer in methinks - did that for 3 minutes ish and then flushed with water again - voila, now it looks like this:
Still not entirely convinced that I did everything correctly - hey ho when its dry I'll scan it.
Cliff
Cliff
