pure sound
Trade: manufacturer/distributor
Have you had the opportunity to analyse the new drive system's signature via the Paul R test yet?
Yup, suspension interaction could be the difference between our experience, no doubt.
I'm very interested to know if you think it flat out beats a 'Geddon. Our decks are very similar.
Do you know when that is being released commercially Andy?
Sorry but why are you surprised it craps on a 'Geddon? The Geddon was great when it came out but it, the Lingo etc are all 80s / 90s technology - the Mober is 2010s technology.
The 'Number9' AC motor controller which I use also blows a Lingo / 'Geddon into the dust.
Andy
Tiger Paw's new Tranquility magnetic bearing support. Despite this being a new mod for the LP12 faithful I've been listening to maglev in various forms on YNWOAN's (Mark's) set-up for years. I know all too well what maglev brings to the table, or rather takes away from the table, so i'm interested to see how the Tranquility does its thing.
The lower assembly is a neat fit that goes straight over any LP12 bearing collar, it's a neat fit, weighs next to nothing and requires no set-up. The top unit that sits in subplatter is a little different.
Or rather Edmund's stainless composite subplatter is different; the mounting boss is just a little bit shorter and slightly narrower than the LP12 original platter. All it needs is a slightly thicker o-ring to clamp it down, but my protoytpe Tranquility came without the production accessory kit. Double sided tape does its thing and order is restored.
Thing is, with the platter on it doesn't look any different. Ride height is the same. Suspension alignment and armboard haven't moved. The belt runs at the same height. It still takes the same time to come up to speed. Frankly you wouldn't know the Tiger Paw Tranquility is there it's so unobtrusive.
Ah, but the veils.
Drop the needle and it's instantly obvious, especially when you drop it on the blank side of a dance music record that i use from anti-skate set-up. There's definite sense of improved silence. I know Mark's own full maglev set-up drops the noise by 3-4db under 50hz, from what I'm hearing the Tranquility does much of the same trick. Pick your cliche, cleaner windows, open windows, cotton buds and ears, all of them are applicable. It's a proper real upgrade, maybe more so than going Cirkus (heretic, burn him).
I'm going to settle down for a night in and have a good listen to some of my favourite records. I might even end up playing some of those hard to get to grips with discs. The humble fruitbox, V2.3.1.465.C rev 2.
