Arkless Electronics
Trade: Amp design and repairs.
Or will soon anyway! One done and other not far off.
I've been promising myself to do this for ages and had said a few times here on pfm about round tuits....
Too busy with customers work to spend much time on them but thought it would be a quickie job anyway... An hour should do it, just got to re-fit the tweeters...
Famous last words.... I'd forgotten that I'd converted them to active... to reach the crossovers and put everything back as it should be means removing all the foam pieces... which are a tight fit and only only go in one way.. crossovers have nuts on inside and have to be removed "by feel"...
Then I found that the crossovers couldn't possibly work! They were just not electrically correct and could not work without either a wire link or a resistor being added in order for any signal to reach the treble part of it.
Much head scratching....
Found a couple of photos of the crossover on google in the end and the penny dropped about "ah yeah I removed those big black wirewounds to fully isolate the passive crossover when I went active!". Then recalled them being on top of an oscilloscope ready to go back... 20 odd years ago in another house...
No idea what happened to them other than I WILL have put them somewhere safe... so safe I can't find them... Anyway a thread on DIY audio mentioned them being 3.9R and that fits with what I remember.
I'd long been using better tweeters with them (Son Audax TW025A1) and recalled being not 100% happy with the HF output level, although damn close and better than standard 770's. I'd fitted an "L" pad to help things but this time I'm making it adjustable, temporarily at least. I have a bag of 20R 3W wirewound presets (rather like the ones in the JR149 crossovers) so I'm extending the wires where the resistor would be in the crossover to a couple of feet long and have them dangling out the bottom of the speakers where they will connect to the preset, with a further 10R or so fixed resistor across it. Hey presto... adjustable HF level! When I'm happy with it I can use a fixed resistor in the normal way of course.
So, spiders rescued and webs hoovered out, foam hoovered, white "alloy mould" removed from bass unit chassis and hoovered up, cones checked for free motion with no rubbing etc.. One done and the other not far off I'm hoping to get a listen before I go to visit a mate around 9 tonight...
Gawd knows how much "burning in" the woofers may need after not seeing elecktrickery for over 20 years.... or if 54 year old me will be as bowled over by them as 17 year old me was... Obviously I've heard a hell of a lot of other speakers, some definitely better than the 770's, since then!
I only actually owned a pair when I was more like 24 and they were my reference that beat all other speakers they came up against for at least ten years...
More to follow
More to follow
