Kit Taylor
Well-Known Member
My sistem suddenly sounding dreadfully thin and raw has prompted some more investigations into my dac project.
I've put a little low pass filter after the coupling cap, 100R 1206 in series and 10nf 1206 NPO to ground. the sound is softer and more delicate and doesn't sound like it's in the room with me. Unusual but not unpleasant.
Would the filter be theoretically better before the coupling cap?
I also want to try a single AD817 as I/V and buffer. The TDA1543 has a Vref resistor that connects to ground, does this need some kind of link to the AD817? What's the miniumum wattage of the feedback resistor?
Also, if I don't use the offset nulling should the two pins that serve this function be grounded?
TIA
Here's dac I'm talking about:
http://pinkfishmedia.net/forum/showthread.php?s=&threadid=4869
TIA
