Originally posted by Ken C
many thanks mark for the info. i always wondered what the acronyms mean. (what about the C in TNC-S?).
i agree stick with supply earth. i have two 10mm^2 radials from the consumer unit to the hifi, presumably this means i have to run 2 THICK cable earths from CU to each radial outlet. since my radials are wired with 45 amp rated T&E, i would assume (perhaps wroingly) that the earth of this cable is rated quite close to 45amps (do you know the actual rating? -- its a bit thinner than the L/N wires)
while we are talking about outlets, do you know where i can get an unfused/unswitched triple socket? the plugs will be fused, so we are still safe.
C - earth & neutral conductors combined.
I'm unclear by what you mean by radials? Spurs?
Apropos your earth cable, current rating is not the issue but resistance minimum value. However, judging by your cooker cable spec I think your into the realm of splitting hairs...
Triple unswitched - try current Screwfix catalogue(no 77) page 177 Part No D12398 - Select 3g @ £6.95 each inc vat.
Want to get serious? Go 16A industrial.
Mark
