darrylfunk
Banned
i take it you volume matched the system? only joking steven.... i know you don't believe in that.
Dynamics are not about volume.
i beg your pardon... The dynamics are very much about volume.
If they are not related to the volume realm just what do you believe them to be related to?
Hi John and Dominik,
I was wondering if you could confirm if the MDAC's clock output is 2,8224 MHz?
Thank you
At +3dB there is no gain scaling & your approaching the limits of the analogue section PSU rails - if you had balance inputs you could get an extra +6dB, as we are talking about tube electronics, maybe a transformer could help here?
At +3dB you have about 3VRMS output that's HUGH - your Tube amplifier appears to lacks Gain! Are you sure its correctly functional?
Which model do you have and did you DIY build it? maybe an incorrect component value (or is it one of the SE low power units? - what speakers do you use?)
If your using there singled ended designs then its a lack of amplifier power - the highest is only a claimed 8W, no amount of output from the MDAC can help at 3Vrms at +3dB its already well over the industry standard output level.
I've nothing against SE Tube amplifiers... only that its not the job of a DAC to provide such High output levels... I really believe the Amplifier design lacks Gain & maybe depending upon your speakers - power (unless you tell me that you have Horn loaded speakers )
I should have said level not volume.
steven level is critical to dynamics too.
this is common knowledge clearly you don't engage your brain when coming out with these hilarious gaffs.
Yes Jeremy. Anyway this is not the thread for crappy obj/sub stuff and ridicule.
It is an unpleasant nit-picking distraction from the fact that I was asked to compare with and without the pre and give feedback. My methodology is known.
Using the pre is definitely beneficial and by that I don't mean proven beyond all reasonable doubt in an a level matched abx deaf, blind, bound and gagged test which, as well as being nigh impossible to set up, would bore the tits off me.
The tests were hands-on and listening was at a variety of volume levels with and without the pre. I trust that JohnW (and Cereal Killer) will accept my subjective findings just as most on this thread accept his before we place our orders.
If you have issues with such less-than-rigorous methology, kindly start another thread outlining your 'concerns.'
the expression in the voices was better with the pre and it was easier to pick out each voice. There was also a slight loss of dynamics without the pre and timing wasn't as good
