Dare I say it.. but does that include the SoC or does it need an additional rail. Or do we assume no SOC.
Do you plan to provide the external PSU, or should we try to source / provide that ?. Meaning would it makes thing easier for you and maybe help reduce your MDAC workload - just a thought.
Some cds are now mastered in a way that the uadiophile market does not like (largely down to dynamic range compression). It seems that at least some people like this though.Would be nice to have some feedback to my post
Yes and no. In general, digital recording, mixing and mastering technology has gotten much better. Unfortunately studio engineering skills haven't - or, rather, record labels push the engineers for a sound that is very "loud" all the time, requiring excessive dynamic compression.
Vinyl records a) can't mechanically take the excessive compression and b) tend to go for more "audiophile" oriented performances.
Welcome!
No problem to power On/Off via a switched power strip.
upsampling to dsd should take the dacs anti imaging filter out of the equation and maybe the modulators, but if the dac is not converting in exactly the same format who knows what's going on? It might end up being converted back to pcm or remodulated.So - again if PCM to DSD sounds superior - this points to problems with the effects of the modulator and how it is subsequently handled?
Because: PCM -> DSD should not inherently sound superior. There is no additional information and any "destruction"of the signal had already been done at time of recording/encoding
So any "improvements" are as a result of the (D to A) conversion process or artefacts of the conversion process
And vinyl isn't always any better because it is often (not always) mastered to a similar level.
For sure thats not what I've heard in the past from Vinyl - even with my systems deficiency the Analogue source is far more "real", far far better sound stage and maybe more importantly depth... every instrument & voice has its own local in space, and no matter how loud the other instruments are you can clearly hear each instrument if you focus your attention to it - it put me into somewhat of a depression for a few days after my first listening session when it was forced home yet again how we lost SOOOOOO much going digital IMO![]()
Except vinyl can't actually physically take the same kind of ultra-loud, ultra-compressed mastering we see on many CDs.
If the original recording is performed digitally with an ADC, then there will a further conversion back to analogue to record the signal onto vinyl. The vinyl would likely exhibit many of the issues that the CD has - the difference being the digital to analogue conversion has happened at the production phase rather than the playback phase. Of course, in the good old days, I believe master recordings were made to analogue tape and the vinyl was cut from these.
MDAC2 / FDAC can support upto DSD512 via USB and DSD128 via SPDIF...
Has this changed? I thought you said earlier that MDAC2 was DSD256. I wish there was a definitive list of MDAC2 specs available.
- Richard
It's one more step up - DSD512 is commercially available, DSD1024 is possible in "lab conditions". Google gives me ie. http://www.diyinhk.com/shop/audio-k...to-i2sdsd-pcb.html#/xmos_option-xmos_768k_pcb amongst the other high-end DACs.Richard,
We have DSD512 working on the bench - but no OS / Software can support such a data rate - I dont recall how we tested it.
Basically the hardware can support DSD512, but the PC software / OS will take time to catch up.
./uapi/sound/asound.h:#define SNDRV_PCM_FORMAT_DSD_U8 ((__force snd_pcm_format_t) 48) /* DSD, 1-byte samples DSD (x8) */
./uapi/sound/asound.h:#define SNDRV_PCM_FORMAT_DSD_U16_LE ((__force snd_pcm_format_t) 49) /* DSD, 2-byte samples DSD (x16), little endian */
./uapi/sound/asound.h:#define SNDRV_PCM_FORMAT_DSD_U32_LE ((__force snd_pcm_format_t) 50) /* DSD, 4-byte samples DSD (x32), little endian */
./uapi/sound/asound.h:#define SNDRV_PCM_FORMAT_DSD_U16_BE ((__force snd_pcm_format_t) 51) /* DSD, 2-byte samples DSD (x16), big endian */
./uapi/sound/asound.h:#define SNDRV_PCM_FORMAT_DSD_U32_BE ((__force snd_pcm_format_t) 52) /* DSD, 4-byte samples DSD (x32), big endian */
edit: Another cheap one - http://rover.ebay.com/rover/1/711-5...0001&campid=5338728743&icep_item=141316861730 ...
The new Matrix Audio X-SABRE Pro claims to be capable of 1024
- Richard.
Its just my opinion, but I dont consider Linux a typical everyday users OS... its too specialised - you need to be a computer geek to use it
I'm getting too old to want to spend any more of my life fighting computers.. it was ok when I was 15 years old with nothing better to do with my life!
