Richard,
Very sorry for the delay, I was thinking in bed this morning that I must reply to you!
The Optical output is routed with the Coax output, so while we officially might not support anything above 96KHz via optical, you should still see a valid but not guaranteed signal - however Coax / Optical output from USB is only to 96KHz due to the USB1.1 interface limitation.
Not recommended, best to use the optional two channel DIC DAC for the subwoofer path.
Mini xlr iircWhat connector type(s) will be on the DIC DAC?
Hi John,
Depends which version but:-
2 Channel DAC DIC:- 2x XLR
4 Channel DAC DIC:- 4x XLR
DAC + HDMI Input DIC:- 2x XLR & 3x HDMI
david, with the FDAC L3 MM/MC
Your arm cable will need an adapter from RCA to XLR or, alternatively, you may be able to rewire you arm for balanced operation (I'm afraid I don't have the details for this at hand).
david, with the FDAC L3 MM/MC, you shouldn't need a pre-amp (unless you want one, for some reason).
Volume on the FDAC will be all controlled in the digital domain (safe for, IIRC, a 20dB attenuator which may be switched on or off automatically).
Impulse H2's lucky you I'm jealous great speakers they really need a good moving coil MM just not good enough, the L3 will have a MM/MC stage so no need for a preamp connect direct.I would wait for John to explain how the balanced input is configured there is more than 1 way to do this.I run a balanced arm cable based on Morgan Jone's suggestions in his book i.e. a balanced cable with a twisted pair inside a shield,each pair is the coil and the shield goes to arm earth and MC stage earth.
John, sorry to be a pain, but I have lost track of payments. I think I have made £400 so far, assuming I am going for L3 - MC/MM are you expecting more at this point in the development process?
John
I've exchanged some emails with Jan about this and he thinks he can increase the output current of the 15-0-15v supply. How many amps would be required?
( I like the option of being able to get off the grid.)
https://linearaudio.nl/silentswitcher
